Mathcad prime MCDX to mathcad 15 XMCD file conversion
AD_11368417
2-Explorer
Is it possible to convert mcdx (prime files) to xmcd (mathcad 15)?
If yes, how to do it?
Hate to be the bearer of bad news, but no not without getting into internal file storage methods of each software,
Cheers
Terry
Any suggestion how to convert .MCDX to .XMCD ?
It is possible to selectr then cut Ctrl+C and paste Ctrl+V each expression and text region in the mcdx to an xmcd file
Cheers
Terry
Cheers
Terry
You are right, it is possible to do so, but for math regions you will end up just with a picture of it and will have to retype all math in MC15 again one by one.
I may be possible to write a converter but to the best of my knowledge nobody so far has done and so the only way is to recreate the Prime worksheet in MC15 by retyping all the expressions. Just if the Prime sheet contains a lot of text and pictures, copy & paste can help a bit - sub/superscripts, highlight colors, etc. will get lost and you still will have to reformat, but at least you won't have to retype the text itself.
Hello @AD_11368417
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
