Mathcad/proe integration -replacing component.
lastdriveon
Can we replace one component in pro/engineer with another component using Mathcad-Pro/ENGINEER integration.
The Idea is I have created a program in Mathcad with conditional segment.And I want when condition is satisfied component A should be there in the assembly otherwise component B should be there.
And I want these changes to reflect in Pro/ENGINEER,means I want to drive these changes in Pro/ENGINEER through Mathcad.
I know how to integrate Mathcad with Pro/ENGINEER but would like to know whether component replacement is possible?
Mayur.
6 REPLIES 6
That would be tricky to do as you need to apply constraints to each component for its location within the Assembly.
Is the part similar shape? The reason I ask is because you could make the part dimensionally driven by Mathcad.
Mike
lastdriveon
(To:MikeArmstrong)
Mike,
Thanks for the reply.
let me simulate the possible situation.
I have an assembly with the Family table instance.
(For Eg:It could be a Gear and its family table.To simplify the process we can also use the interchange assembly).
Depending upon the condition in the mathcad I want the Gear A to be replaced by Gear B or viceversa.
Gear A and Gear B might be different in Number of teeth and diameter.
So the condition in Mathcad could be as follows:
If N1/N2<2 then Gear A
else Gear B.
Note:
N1/N2 is speed ratio.
Use of family table and Interchange assembly is to simplify the modelling.Things can be driven smoothly from Mathcad to Pro/ENGINEER without involving lot of parameters and functionalities.
Eagerly waiting for your insigt on this.
Mayur
I have been looking at the best way to achieve this. I have only recently started learning ProEng and not yet fully up to speed. If you only require Mathcad to specify the Gear assembly to be loaded. There might be a easier way.
Let me have a think and I'll get back to you.
Mike
lastdriveon
(To:MikeArmstrong)
Thanks Mike.
Even I will simultaneously here on my end will let you know if any updates are there.
I have got a function that will load a specific ProEng file depending on results in Mathcad, but I'm not sure this is not directly what your after.
Mike
I think there is a way.
We haven't yet got our Pro/E Mathcad intergation to happen (need to get Pro/e up to the right version reliably!).
But I have seen video's and presentations of it being done.
Have a look through the PTC site for those presentations. I don't know enough about what neeeds doing on the Pro/e side to make it do the calculation and then use the result (pro/e can seamlessly do that), and them majke its next step. The example is an F1 car brake, with variable number of brake discs.
Try here http://www.ptc.com/appserver/wcms/replay/index.jsp?&im_dbkey=42009&icg_dbkey=362
Philip
Added link.
