Matrix Complex Subraction
rjaison
I have two one dimensional matrix An & Bn
n= No of column of the Matrix
Please see the attachment, which is quite easy to understand what I want to achieve
PS I am using Math CAD 14
LucMeekes
(To:rjaison)
Attached is a version that returns the result with units.
Note that Mathcad internally stores values with its internal representation of a unit. That's m2 (metres squared) for areas. If you want to display the result in mm2 (millimetres squared) you'll have to type mm^2 in the units placeholder following the result.
The calculated results should not differ for different input/output units, provided that you account for those units. So if both input vectors are given in mm2, you'll get the result (by default) in m2. Now realise that 1 m2 = 1 000 000 mm2.
18 REPLIES 18
RichardJ
(To:rjaison)
Not to me. I understand how you get 0 as the first answer, and 600 as the second. Please explain the logic you use to get 0 as the third answer. It looks like this was calculated in an Excel spreadsheet, in which case please post the spreadsheet.
I am sorry I made a terrible mistake
Please see the attachment "Complex Matrix Corrected"
BR,
J.Randeep
rjaison
(To:rjaison)
Hi Everyone,
I am still struggling with this Matrix Complex Subtraction
I am thinking it is more like a Boolean Subtraction, but I couldn't figure this out though.
May be somebody comes up with a genius solution !
J.Randeep
RichardJ
(To:rjaison)
Your question is still not fully defined. In your example the colored sections are all separated by a case where An=1000 and Bn=0, so the result is 1000. What to do if the colored sections overlap (for example, if the third element of Bn is 1100, or if the 9th and 10th elements of An and Bn are removed)? What to do if the sum of Bn is greater than the sum of An?
StuartBruff
(To:rjaison)
Could you please post an image with the Formula display turned on for your Excel worksheet? That would give us more idea of what your are trying to achieve and possibly suggest a way of implementing it within Mathcad.
Stuart
The Excel is just a principle of what I would like to achieve.
There is no actual calculation in that excel sheet, it is just a text.
But any ways I have attached that Excel Sheet, if it is of any help!
I can further clarify if you need any.
J.Randeep
LucMeekes
(To:rjaison)
You give a puzzle, you get one in return.
See if attached sheet performs as you want it. Also with respect to Richards question: what if the regions overlap?
If not, send it back with more examples of what the output should be with given input.
Hi LucMeekes,
It is exactly the way I want it to be..
It is so perfect
About the overlap in the region there wont be any, as the constrains are set according.
How can I adopt this into my Math CAD sheet it seems like some kind of the special code.
Could you please advise.
Thanks.
J.Randeep
LucMeekes
(To:rjaison)
Just insert my sheet as a reference in (the top of) any of your sheets where you need the function
(From the menu: Insert -> Reference).
Have you tried different values in Vector A too?
rjaison
(To:rjaison)
P.S I hope this subtraction function with any n number of row matrix.
J.Randeep
rjaison
(To:rjaison)
I am getting this warning.
Is that mean if I do the reference as you mention then I have to have this sheet in the system I am working all the time.
Is there any way, I would preferred to have them in one sheet
J.Randeep
rjaison
(To:rjaison)
Hi Again,
Yes I made a mistake on the Syntax I used minus sign instead of comma.
Yes it work fine with a bigger matrix as well.
Please do advise on the reference thing...If I would like to have that function in the same file without the refference
J.Randeep
rjaison
(To:rjaison)
I had one problem when the input matrix A and B has a unit mm2 when it dose the subtraction the output comes as meter2 as I have math cad sheet in SI unit system.
But when I change the output to mm2 the summation of the Output Matrix is quite different.
J.Randeep
LucMeekes
(To:rjaison)
RichardJ
(To:LucMeekes)
Out of curiosity, why bury it in a locked area? What's so secret (if it's not so secret that you can't even tell me why it's so secret )?
LucMeekes
(To:RichardJ)
Rich,
I hid it because I wasn't really finished with it, because I wanted some more info on the borderline cases, but mostly because it was ugly.
I now attached a worksheet with two different implementations that I find presentable.
RichardJ
(To:LucMeekes)
. I have published ugly code many times because I was too lazy to make it nicer. If I provide someone with a working but ugly solution they can make it pretty if they wish to spend the time
It works perfect now.
I guess I have to use this function as a reference on the contrary I would have preferred this function in the same calculation sheet itself.
any ways, thanks for your help.
BR,
J.Randeep
