Hi all,
After getting the correct answer for the if statement part of my equation see post - Three if Statement Formula (I have altered this figure to exactly what I want now) I now thought it would be great if I could check multiple figures at one time using a matrix for my inputs. I've come across a stopping point straight away!! Booooo
Again I'm not so wise with Mathcad so I look to your guys opinion on this issue I have.
Please find attached the formula I'm currently working on. (Mathcad 15 format)
Best Regards
Jonno
It's complaining about scalars because when you do vector=scalar, Mathcad returns 0 (because a vector isn't a scalar!). You need to use the vectorize operator to compare the elements of a vector with a scalar ... and then you need some method of using the resultant vector of true and false (1 and 0).
It's probably simpler to make your expression into a function and call the function with the vectorize operator, or put your expression inside a for loop (and use it in a direct program or inside a function).
Stuart
