Minimizing for a family of functions
AlvaroDíaz
9-Granite
Hi. How to minimize a family of functions over the same range with the same given-minimize block?
Regards. Alvaro.
39 REPLIES 39
>How to implement this ? <<br> _________________________
Implement what ?
I gave you the working "Golden ratio"
Just plug your stuff in there.
jmG
RichardJ
(To:TomGutman)
On 10/25/2009 1:03:52 AM, Tom_Gutman wrote:
>Here's the version that works
>in MC11 and MC14. Also how to
>use arrays to automatically
>iterate over the target
>functions.
The use of arrays doesn't work in MC14. Not that important; I'm just making an observation.
Richard
Another bug in SUC (SUC SUX). It is not properly recognizing that the vectorize operator removes a level of array nesting. And it is complaining about the use of arrays where scalars are called for. Doing the same thing using explicit range variable iteration works.
__________________
� � � � Tom Gutman
RichardJ
(To:TomGutman)
On 10/24/2009 4:39:39 PM, Tom_Gutman wrote:
> Perhaps it has
>to do with minimize not being
>an actual function (note the
>inability to get a signature
>for it) but a special form.
>As such, it presumably needs
>special code in SUC, code that
>was not provided.
Yes, interesting observation.
That's probably also the reason solve blocks always give the same useless error message about undefined variables, regardless of what the problem actually is.
Richard
On 10/24/2009 10:19:58 AM, rijackson wrote:
>On 10/24/2009 6:36:30 AM, adiaz wrote:
>>Amazing technique.
>Yes, but unfortunately one that does not work post version 11. SUC strikes again (it requires that f be a function, whereas in fmin(f,x):Minimize(f,x) it could be anything).
Thanks for the adverting.
Regards. Alvaro.
___________________________
My work sheet MCD11], does it work for you ?
If it does, it will as well in lower versions.
jmG
>you ?
>versions.
>jmG
Code it for the applicable version.
jmG
Works fine, thanks.
Regards. Alvaro.
>range with the same
>Regards. Alvaro.
______________________________
By introducing a dummy guess argument in the functions and assigning the solver carrying a dummy objective argument.
Saved Mathcad 2000, unknown if working in 14.
jmG
Another criterion: brute force scan, interpolate, find critical points, select the interval and finally call minimize or user defined algorithm, as parameter to the fmin function.
With derivatives, but reduces the target function calls.
Alvaro.
