I need to find for each column of a matrice the minimum value (> 0) in that column (pos_6 as defined by the attached ; the maximum is obtained by using "max" function..
). Please help!
Kind regards, D.
Dumitru Moldovan wrote:
It's about finding the minimum positive number foe each column in the matrice...Thanks for the attached. I'll take a look into it.
OK, Dumitru. Try the attached worksheet with function minnzpos1.
Stuart
). Please help!
Kind regards, D.
Dumitru,
I'm not quite sure the attached will do what you want, but I've created a function, minnz, that hunts for the minimum nonzero number. Do you require it to specifically look for the minimum positive number of just the least number > 0?
Stuart
Or if your matrices aren't really big maybe you can use something like this:
Magnus
Stuart
Dear Stuart, thank you for both your sheets. You answered my question.
Kind regards, D.
