Hi Folks,
I would need your help to test the attached mathcad worsheet.
For me, it is not working properly (multi selection sometimes fades away) but for others it seems ok.
Thanks for posting your feedback.
-JM
Working fine for me. M15
What version you running?
Mike
M13 but I suspect my HP Elitebook laptop to be the main culprit ;-(
Jus to be sure... you press crtl button to multi select right?
thx
-JM
Yes.
You say the multi selection seems to fade away?
Mike
Problems that I can see are:
1. that if you select a higher line (e.g. me) followed by <ctrl> and a lower one (e.g. beer) - only the lower entry is highlighted.
If you start with the lower & follow it with the higher then the both (multiple) will be selected.
exception: me + another sometimes works ~1 time in 10)
2. selecting please followed by pour (with <ctrl>) just selects these two lines.
selecting please followed by me sometimes selects just the 2 lines but can select me + another +beer + please.
There doesn't seem to be any way to predict which result will occur from any one attempt.
Looks like it could be an interesting control.
Andy
I think this component is a must have...
I am "glad" ;-( to see that you have experienced similar issues.
Look like that we need some tempo in the script because the selection speed seems to have an impact on the final results!!!
Any help is welcomed
-JM
