Need urgent help for this problem in Mathcad Prime 4.0 , What is the problem here ? The file is also attached in this post.
Thanks in advance.
The equations are empirical so not unit consistent. This is a hint on how to handle the units with Prime.
Cheers
Terry
The definition of a function cannot be equal to anything. You need to delete the equal sign on the right hand side.
Cheers
Terry
Additionally you may want to check your units
Cheers
Terry
