What is the difference ?
ppal
18-Opal
Please see attached Mathcad (prime 5)- Won't let me past the picture. So pic also attached.
Exceeds 2000 words or something
(To:ppal)
The vectirization (arrow over t) never is necessary and its confusing. use it only if you calculate with vectors, not with ranges!
t is a range, but Rows is a vector - thats the reason for the different answers.
A range is not a vector but kind of an implicit loop. It has 0 rows.
Its an undocumented trick that a range is turned into a vector if you use inline evaluation.
x:=1..5 is a range, but
y:=1..5= is a vector.
tsilence
6-Contributor
(To:ppal)
Here's a little image showing what Werner is talking about.
As you can see, using inline evaluation, T := t = [row vector] provides the results you desire.
- Trevor
Tech-30 Application Engineer
Check out our YouTube channel for instructional videos on PTC products.
