I'm trying to solve a 16 equation, 16 unknowns simultaneous equation but keep getting 'no solution found'.
I am recreating a worked solution that i've seen (albeit in a newer version of mathcad) although i don't have the original file, only a screenshot of the code.
I can't seem to get this to work, any advice is appreciated.
Use plese at first the minerr function. Usse solution as guess values and than use the Find function!
See please the attach - Prime 6
