On 11/17/2009 11:27:32 AM, jmG wrote:
That's is what I do: find non integers coeffs and visually looks for the mcd (max common divisor) visually setting mathcad output as fraction to multiply by this factor the first solution (as is shown in the attach of the previous post).
Here only shows an advanced method to solve the coeffs dependency.
Also, there are rules about the degree of fredoom to balance a chem equation (which I'm not have at hand).
This methods also are "brute force", are better (conceptually) those use semi-reactions. But I don't know species that are involving in this example enough to show how-to in this case.
Regards. Alvaro.
