Node analysis matrices with input array
- August 3, 2020
- 3 replies
- 2664 views
I tried to do a node analysis with a resistor matrix. The input of the voltage matrix should be variable, therefor I introduced an array with voltages. After the solver I get an error "This value must be scalar or a matrix.". What must I do to get the rigth result, doing the calculation without array works.
