Non- linear equations system solution but i want my answer to be matrix form
aizham3
3-Newcomer
Hello since im trying to find the unknown with 6 different initial values and 6 non-linear equations I try to use find but I cant obtain the value but there is one variables in the equation got counter.Hope u guys can check for me.
(To:aizham3)
Guess the attached sheet should help
6 REPLIES 6
see pls attach
Okay thank you so much for your help but the 6 unknown only for  one V or should I say speed but how do I present the data for the 6 unknowns for the 10 different V in matrix or table is it possible?There are some modifications I have made from your Mathcad..
You can create the user function Ans(I):=Find(...
thank you the function this supposes to be like this
Trim(V):=Find(CL,CLw,Cd,Ct,ae,Clt)
But im not sure it says that my Trim is variables is undefined and im a bit confused right now..sorry im still new to mathcad
(To:aizham3)
aizham3
3-Newcomer
(To:Werner_E)
Thank you for your soluton it really helpsme a lot
