Not converging
  • January 25, 2017
  • 3 replies
  • 7523 views
I hope everyone is doing great. I need a help to solve an integration that linked with summation also. I will be very pleased if anyone can help me. The problem is in number 2. I am also giving the main file of the task.
Faisal
23-Emerald I
January 26, 2017
Just looking, but I think your integral
is all constant terms that could be pulled out of the integral. the integral then evaluates to h_i and the summation should evaluate.
23-Emerald I
January 26, 2017
Following up.
(In the future, send a Mathcad file, not an xps.)
There were several places where vector lengths had to be adjusted to match.
fahmed-31-VisitorAuthor
Thank you very much for the help. Can you please mention why did you use the ( Ctrl+shift+^) for finding the solution or what is the name/use of the operator. I am trying to search the help file but since I don't know the name, I can't find it.
Faisal
23-Emerald I
January 27, 2017
"Cntrl+shift+^" is the vectorization operator (matrices/tables\operators) and results in the arrow over an expression, meaning, "do this operation on each element of the vectors separately."  It results in a vector result.
Why did you think I hadn't used it?
That is also the reason I had to add elements to your vectors for z and h--all of the vectors in an expression have to be the same length or vectorization will crash.
Thanks a lot everyone......I really appreciate your time towards my concern
