Hi everyone,
I seem to be here relatively oft in the last times. ![]()
I am trying to write a file-reading-loop where a certain number of files (in different directories) are read one after the other and processed in a certain way, then the results should be written out to a "summary" file. Now, a prototype worksheet works for a single file, even the biggest of them. But when I start the "loop", after a while I get the infamous message "not enough memory for this operation". With Task-Manager I have looked at the memory requirements, and they stay to 14%! The following snapshot was taken immediately after receiving the error message and it is showing memory used 14%.
Does someone know how could I avoid this problem? either "telling" Mathcad that it should use more memory, or somehow in my algorithm "clearing" the memory after each file read? because I do not need to have all files in memory, actually all what I need, is the capability to program a loop in order to perform the same operations on many different files. So each new READFILE actually overwrites the previous one in memory, and it should not need more memory (the result of READFILE is loaded into the variable PSDfile, every iteration).
thanks for any help & best regards
Claudio
PS: I' not posting the Mathcad-Worksheet (at least at this stage) because it works only with my specific data files.
PS2: I have a few debug statements, but the problem happens also with debug turned off.
Its nice you have 32 Gig of Mem in your machine, but unfortunately Mathcad 15 can't take advantage of it - its architecture is too old. Prime should circumvent that limit but has (too) many other drawbacks, restrictions.and limitations.
I don't known if there is a way to influence Mathcad's garbage collection.
Using READFILE you can specify the start and end row to read, so you could read in the file in smaller portions.
This would complicate your program and I am not sure if this would really help to prevent that error.
Whats the file size, number of rows, of your six data files?
Guess we would need your worksheet and all data files to play with.
Another idea which comes to mind is that you could put the reading and processing of 1 file in another program which then is called from within your main program. The memory occupied by the file should be freed at least when the (sub) program is left. Again - its just an idea you may consider, no guarantee for success.
By the way, Werner,
when you say "reading and processing of 1 file in another program which then is called from within your main program."
do you mean something like this?
I just moved the reading out, because it is there that the problem happens...
unfortunately this does not help. Now I will try to put the complete processing inside the loop in another program...
Regards
Claudio
Unfortunately it does not work even with the complete processing in a different program.
The next try would be to put the whole processing in the subroutine "processPSD". Also the generation of the two files. So "processPSD" would return nothing to the calling main program.
I don't know if this would help, though. It could be, that memory is only freed when the outermost program is left and not, when a subroutine like "processPSD" is left and gives control to the main program. But it may be worth a try.
If not, as your calculation just need one column of the file after the other it may be a way to split the process in smaller parts in another way.
One routine "rc1" which just deals with the first half of the data, another "tr2" for the second half. And then a third routine which reads the two half files generated by thos two routines and appends them to the final one. Awkward, but maybe a possible workaround.
it's getting better! Now it is stopping later as before. I will try to use also the row-selection in READFILE (where now I just say "3").
In the meantime I have to say that I jumped to an example where I have 7 directories but two component-files per directory, so in total 14 files.
I am very grateful to you, Werner, for your advice. Hopefully this is what you mean... I actually never thought of "calling" a function without passing back something, so at first I was unsure if I should write something like: dummy <------ ProcessPSD(...). But it seems to work just invoking the name.
Yes, what you did is exactly what I meant.
In fact even your new ProcessPSD has a return value. Its the return value of the last statement - the APPENDPRN command. Its return value is the data it has written. But as this matrix is not caught in a variable in the main program, I guess no memory is wasted that way. To be on the safe side you may add a line below the last APPENDPRN with just a "1" (or "return 0") in it. Then not a matrix is returned but just this number. But I don't think that this would really help. The error occurs in the subroutine "ProcessPSD", so no memory seems to be cleared after the main routine has called this procedure - bad news.
But Mathcad never was famous for a satisfying garbage collection. I remember some threads here where subsequent calculations with big matrices which then were deleted made it nonetheless necessary to close and reopen mathcad because of an out of mem error. So garbage collection, freeing unused memory, is not working as it should - not even on worksheet level.
Hi Werner, thanks!
You are basically confirming my thought, about memory. That's a pity! And for Prime... I agree with you.
Concerning the files (I am not going to post them, for proprietary reasons and because it would simply be too complicated, they are in different subdirectories and so on). They contain power spectral densities of a vibration measurements, each line has a time stamp, a few general information and then 500 values (0, 1, 2... 500 Hz).
In the test that I am running as first example, the files are:
For the first subdirectory three x,y,z-Files: 2900 lines each = 8 MB each
For the second subdirectory (where the out of memory problem arises): 19500 lines = 57 MB each
I am having a partial success with the selection of the columns to read. But I would like to wait if someone else in forum can suggest better. Anyway limiting the frequency to 400 Hz (instead of the available 500 Hz) the program ends correctly. Only one time
... then I have to close Mathcad and restart it!
So now the program looks like this and works with the input shown:
Regards
Claudio
Just to give back something to the forum, I am posting here the final version in a simplified form (but without the input files, of course). Maybe it could be useful as a starting point for someone else having a similar problem. Basically the purpose is to read in batch a few files with structured names in given subdirectories of the working directory, make some statistic processing on them and append one line of summary to "high-level" summary files with appropriate names in the working directory.
Thanks a lot to Werner Exinger for the precious help and advice. I also added a personal modification that finally made the limitation on the number of rows unnecessary. Namely substituting READFILE("delimited") with READCSV (actually, they do the same, for "delimited" files, I think). But as a matter of fact, with READCSV everything goes a little faster and I did not need to reduce the number of records read (in my example).
Of course if someone knows a good method to reduce memory occupation (in the sense of garbage collection), I would anyway appreciate to know.
Regards
Claudio
