Numeric display of plotted points - XY plot in Mathcad Prime 3.0
abirlea
I was wondering if there is a way for seeing a readout of coordinates of the specific points that make up a trace in an XY plot.
In Mathcad 15 it was possible to right click on a graph and select Trace which displayed the x and y co-ordinates of the nearest point when you clicked on the graph near a point. Is there a way to do this in Prime?
5 REPLIES 5
RichardJ
(To:abirlea)
No. One of the many missing features.
abirlea
(To:ValeryOchkov)
Adding markers is not exactly what I was looking for... But can you set the intersecting point of the markers to follow the trace and then drag one of the markers around?
RichardJ
(To:abirlea)
Not in Prime, no. In Mathcad 15 it would be possible to rig up something like that using some scripted controls, but scripted controls are not available in Prime.
athurin
(To:abirlea)
if you are plotting a function, say f(x) versus x, you can define the value of your horizontal cursor as "f(3)". This will set it to the right level, and display the actual value on the graph.
