Hi Mike,
I use a ComboBox control to find all regions with tags and then scroll window to the region that you select from the control. It works well on a windows server. However, when it works on a citrix server it popups a error message :
Do you have any idea about the cause?
Best regards.
Jeffery
Jeffery,
Unfortunately I do not have an idea why it doesn't work on a Citrix server as I have use Windows.
Hopefully someone else on here will be able to help.
Mike
Hi Mike,
Thank you all the same.
Best regards.
Jeffery
Been having a think and you could try the attached table of contents. Uses a listbox instead.
Mike
Hi Mike,
Thank you very much for your useful advice.
Best regards.
Jeffery
No problem Jeffery,
Let me know if you get it to work.
Mike
Hi Mike,
I use "Hyperlink" to get it work. Thank you.
Best regards.
Jeffery
Cheers for the update Jeffery. Such a shame you cannot get it to work.
Mike
Hi Mike,
Im also encountering the problem of Jeffery, but im using windows7 and mathcad15. I also tried the one you attached, it also says object required Combobox1. Is there any missing plug ins or anything in the software? im sorry but i really have no idea why it doesn't work. Thank you very much
Very strange.
Have you tried editing each of the scripted components individually and clicking the apply button. This usually sorts the problem.
Mike
