Older Mathcad file conversion
pstory
I have some old Mathcad files I downloaded.  The are Peng Robinson based files and would do bubble point pressure, dewpoint pressure and temperatures.  They can be useful, but I have no means to update the files to the present Mathcad.
Converted to Prime 2: best tyo check the performance against known data to ensure no oddities.
regards
Andy
mnori
(To:pstory)
Is there any guideline to use these files, e.g.( for azeotropic mixtures, for mixture with components with very different boiling point ? ), because it seems to me that their usage is not straightforward.
Furthermore there are similar files also for LLE calculations?
VladimirN
24-Ruby II
(To:mnori)
The following links can be useful for you:
mnori
(To:VladimirN)
Thank you Vladimir,
In extending the files to calculate all the bubble-dew curves as basis for VLE data fitting , and I found some  convergence issues.
