One catenary problem
ValeryOchkov
The description of the problem is here - http://communities.ptc.com/videos/1549#comment-11596
Help me please! My first step is in attach. Is it any right direction?
127 REPLIES 127
Sorry but I see it this brench of PlanetPTC so:
Valery: I have one model and need one more equation. Help me please.
Werner: I feel that the model is wrong but have no time to point it.
Where now is Tom Gutman? Does anyone know?
Looks like he hasn't logged on in a couple of years:
http://communities.ptc.com/people/TomGutman
TTFN
TTFN
Thanks, I have seen it too.
Can we call to the Phone on this page and ask someone?
Mr. 007 - it is any search work for You!
(To:IRstuff)
TTFN
I remember that at the time the collaboratory was moved over to this communities with all its problems, drawbacks and errors, Tom reported having big difficulties with login without getting any help from PTC staff. I am not sure but I guess he left in frustration.
A big loss for the forum anyway.
Werner Exinger wrote:
11 unknowns, 9 equations and no solution found 😞
Maybe we should not expect two catenaries.
Look if the chain has to hold a bridge - at equidistant points we may apply vertical ropes to hold the weight- This time we don't get a catenary but a parabola!
Sorry.
It is not a parabola but a set of catenaries (chains) with a form of parabola.
Sorry.
It is not a parabola but a set of catenaries (chains - near line) with a form of parabola.
I have checked it myself
So you have seen its neither pieces of parabolas nor pieces of catenaries but just straight line segments 😉
If it is absolutely flexible catenery/chain placed between two attachment points, it takes the form of a catenary (hypercos). Builders do lengthes of the vertical suspension bridge cables such that the load of each vertical rope was the same. This leads to the fact that the attachment point pass through the vertical ropes parabola. But we have a catenery between the points curve, which is close to a parabola because the main two rope bridge is not absolutly flexible.
If we can image an absolutely flexible chain we also can image making the distance between the vertical ropes infinite small. Its only that way we get the parabola of course.
More two equations - balances x and y forces in the point 0.
Tomorrow I will try to do it. Now I go to bed. In Moscow 22:40
Werner and Mikko - you have more 2 hrs (20:40) for do it before go to bed
I think it is one more equation we needed:
cat7.JPG:
If you state c=c, then B1&B2 are known due basic geometry and load position.
A1&A2 are unknown, but dependend, thus leaving us with one equation and one variable?
Also load point must be on catenary, which gives us one extra condition for system of equations.
Maby you have a point here...
Mikko,
when can we see your own Mathcad sheets or edited our?
It's hard to impove pavement laid by masters, but I try to contribute something later. Honestly.
You welcome, Mikko!
One fresh man - one fresh solution!
Well, I don't know about freshness (newborn in house) but here is something (Prime 3) that you might consider either as good joke or a new direction in problem...
Fine, Mikko!
1. See in attach my little correction (not Find but Root).
2. Now we/you can convert it in M15 and create an animation. But where ia the load? No animation - no solution!
Thanks Valery,
there is a solution for vertical point loads in the refrenced paper - so, there is some hope that it will be possible with Mathcad as well. Lets see if I/you/someone on community has some time to type it.
You seem to be very keen on animations. Personally I would like to see macro buttons in Prime 4.
EDIT:
yeah, root is much more elegant than find... this is what you get when using copy paste at end of day.
Message was edited.
In a catenary, the horizontal tension is constant.
You can develop enough equations to find a solution.
Yes - in the point 0 too
Thanks, Fred. I have lost my dream...
But change please H1, H2, G etc and see the plot.
I don't see a problem. You can set up the solve block as a function.
Hmm, changing the weight G from 10^-3 to 10^6 (the smallest and largest values allowed) does not affect the graph!??
The smallest value of G must be 0
The smallest value of x0 must be 0 too etc
We must create 11 equations with 11 unknowns and try to solve it.
But I think Mathcad cannot solve it. We must put fine guess values.
But let we try.
You'll laugh, but there is any solution!
Check it please!
Great job Valery!
A humble Thank You!
Solution seems to be stabile even with one real case with:
  • H1=16m, H2=11,75m, L=126, S=129, G=240kg, gc=0,41kg/m
Now, back to problem set - "elastic catenary with point load". We are on halfway of our journey...
Hints:
http://communities.ptc.com/message/93073#93073
http://communities.ptc.com/message/30594#30594
See the video here http://communities.ptc.com/videos/4417
But the solution is not stabile - catenary-arch-catenary-arch etc
We must think about more good guesses. Use for example in new step solution of the last step.
And no problem with elastic catenary...
Not so crazy catenary with load.
There is nothing so aggravating as a good-looking wrong answer!
The best answer on a good-looking wrong answer is one good-looking correct answer!
