Optimization with Genetic algorithm
ValeryOchkov
Optimization with Genetic algorithm.
Try pls Mathcad Server with your test function f(x, y) - http://twtmas.mpei.ac.ru/mas/Worksheets/Minimum.mcd
and see the picture:
PS I would like to create a video but sorry - no time.
19 REPLIES 19
One more solution with genetic algorithm:
http://twt.mpei.ac.ru/ochkov/Mathcad_12/3_31_Genetic_1.png
Murarz
(To:ValeryOchkov)
Hello!
Does this GA works for a 5-variable function?
yes
I guess the question (implicitely) also was if you would be so kind and share the worksheet 🙂
For most of us the Mathcad Application Server pages aren't that helpful.
Sorry!
See please the attach!
Tell please us is all ok for your function!
We will see if  Murarz  will come back and is able to use and adopt your sheet to minimize his 5-argument function.
See this thread
https://community.ptc.com/t5/PTC-Mathcad/Optimization-problem-using-minimize-function/td-p/592435/jump-to/first-unread-message
for the function he has in mind.
Murarz
(To:Werner_E)
Hello!!
I am back ! I will try for sure, thank you 🙂
Thanks!
I am waiting your results!
Murarz
(To:ValeryOchkov)
Just one more question, xb, xe and yb, ye is the range (in this case for two variables) where the function looks for the minimum ?
xb, xe, yb and ye are for 2D problem.
There is a trick for 5D problem  too!
Murarz
(To:ValeryOchkov)
I know they are for 2D problem, just wanted to make sure what they stand for. I don't like tricks 😛
Murarz
(To:Murarz)
Could you give me some clue? 🙂 I've been struggling with this and have no slightest idea where to even look for.
One method of the choking the minimum of the function of more than 2 argument:
Murarz
(To:ValeryOchkov)
From the figure I see you use minimize function. Does the same applies to the MGA ? Would be a possibility to send the file in xmcd ?
Sorry, I have not the xmcd-file. But you can create it yourself using the picture.
I can create it myself too - but...
Murarz
(To:ValeryOchkov)
Thank you 🙂 But can I this trick of yours apply to the 5-variable function for the genetic algorithm? I mean how should I specify xx,xn in this case since as you said it is for a 2D problem? To be honest I don't understand what you have achieved with this.
Was it about fixing 3 variables from the minimize function, and looking for other two from the genetic algorithm ?
Murarz
(To:Murarz)
Can I get any piece of advice how to convert this genetic alg for a 5 variable function ?  I am still dealing with this but with no sucess. 😞
Murarz
(To:ValeryOchkov)
Thanks for the reply. But I still can't connect the dots. I assume that it relates to the previous post with the guessed values and 2D plots while using the minimize function. But my point the whole time is in using this 5D function for the Genethic algorithm where there are many local minima. Will it work in this case too ? I mean how should I specify xe and xb ?
