Optimization
ptc-4510012
Optimization
i am attempting to do an optimization problem for my machine design 2 class and am having issues.
Basically i have 2 number, N1 and N2, and i need to have mathcad use an equation CT and find values using the N1 and N2. i hope that made sense. if not i hope the attached a copy will explain it better.
CT is a cost equation, where i then need to find the lowest cost between N1 and N2,
then i have to redo the equation this time using N2 and N3 and find the lowest cost there.
next i need to find the lowest cost between the 2 cost equations.
thanks for any help
Case
Sorry,
why do you not need units in your task:
i had issues figuring out how to work some of the equations with units, so i left them all out. thanks for showing me how to add the $ sign in, hopefully the units will work now.
Valerie you dont happen to have the rest of the program like what is shown above?
