Ordinary Differential Equation Error
aiyer-2
Hi Everyone,
I'm using Mathcad Prime 3.1 to solve ordinary differential equation. I'm doing a practice ODE to learn Mathcad Prime 3.1. When I type Given and type the rest of the equations as provided in the examples, Mathcad is not able to read the function "odesolve". When I open a Solve Block and use the same, I get an error saying "The arguments of odesolve are not correctly specified" even when the arguments are provided properly as given in the example. I have attached a screenshot of the same. Please someone help me on this.
ViktorKorobov
(To:aiyer-2)
See picture.
Viktor
(To:aiyer-2)
The Given ... Odessolve "bracket" was used in Mathcad 15 and below. In Prime you must insert that ugly sove block instead.
Furthemore the syntax of Odesolve has changed a bit from Mathcad to Prime, that's the reason your try was failing. Viktor already showed the correct syntax.
