PDE Problem
SavitriN
8-Gravel
PDE Problem
Hey guys,
Now i'm trying to model the concentration in respect of time and space and that's why i'm using PDE solver. However why it does not work and it gave en error that "it found singularity while evaluating the expression.
Help please :(((
7 REPLIES 7
-MFra-
(To:SavitriN)
Hi SavitriN,
it is better to simplify everything......The following  solution isn't tested:
-MFra-
(To:SavitriN)
Hi SavitriN,
the following is a revised and corrected solution.
Thank you very much!
I will try that 🙂
The difference between the file 1 and file 2 that you sent is in the argument you put in the PDE solver. But is that affecting the result?
Because i'm trying your second file and it seems like it does not work again 😞
-MFra-
(To:SavitriN)
Hi SavitriN,
sorry, in the solve block the derivatives must be written in the compact form:
AlanStevens
(To:SavitriN)
Here's my simplified solution:
Alan
Thank you for the response.
Yes i will try this solution as well.
Cheers
