Would you please see the attached worksheet and help me to generate a polynomial for p(alpha)?
Thanks for your time and help.
Anousheh
What was the problem? The divison by zero because of the (....)^(1/alpha)?
p(alpha) is not defined for alpha=0.
Use the same method but don't go too close to zero. Start xx at, say, 0.001.
Alan
Hello Alan,
Thank you so much for your reply. It works.
Anousheh
Hello Werner,
Thank you again for your time and help. I appreciate this very much.
All the best,
Anousheh
Hello Werner,
Could you please tell me how to write the actual POLYNOMIAL FUNCTION?
I tried to use "Symbolic Evaluation" sign, but it didn't work!
Anousheh
