Parabola problem
jsievola
Parabola problem
I'm having a problem with defining parabola's function f(x) when a,b,c are unknown. I can solve a,b,c with given/find-procedure but I have no idea how could I make mathcad to give me the function included these now known a,b,c (something like: f(x) = 4x^2 +3x + 1)
I attached my work so far so maybe it's easier for you to understand what I meant above.
I would be very pleased if someone could help me out as soon as possible.
Sincerely,
Joni
(btw I'm using mathcad 15)
AlanStevens
(To:jsievola)
Have a look at the attached.
Alan
6 REPLIES 6
StuartBruff
(To:jsievola)
Sincerely,
Joni
You simply write the function down pretty much as you have it above!
f(x):=a*x^2+b*x+c
and that's that.
As you've used x as a variable already, if you want to plot it in 2D, then you'll have to plot it against a different variable (doesn't matter what as long as it's not x, y, a, b or c.
Stuart
Thanks for fast response mate!
But I'm still wondering what is the command for solving the function itself. I need the program to form me the function ( f(x)=something ) using now known a,b,c values.
It should give me it example in this way: f(x) = 4x^2 + 2x + 3
I hope you understand what I meant since english isn't my native lanquage:)
AlanStevens
(To:jsievola)
Do you mean something like this:
Alan
Yes that is exactly what I need! I would like the program to show me the function of this parabola but I 'm struggling with it.
AlanStevens
(To:jsievola)
Alan
Oh I got it to work! Thank you very much everybody! I just had to change the variable x to be something else and now the program gives me the function.
I guess I could say case closed:)
