I apologize for what is probably a simple question.
I am using Mathcad prime and in some of my caclulation results I am getting parenteses around the answer such as (1.113). I am sure there is a simple explanation for this but I cannot seem to find it in the help
Mike
Its always better to attach a worksheet to clarify what the question is.
Its nearly impossible to guess what your problem might be - best guess is that your result is not a scalar but a 1x1 matrix.
This is, among many other possibilities, the case if you use one of the "lookup" functions which will always return a vector.
But without anything to look at its hard to tell.
Sorry Werner,
I have attached the work sheet. I have also highlighted the areas of concern I have with red text
Mike
I wasn't aware of this as I usually use Mathcad and not Prime.
It seems to be a setting PTC had chosen for Prime differently to Mathcad to clarify what number a unit belongs to. It shows up when the number is formatted using scientific (or engineering) format with a powers of ten in combination with a unit. Its a setting which you cannot change, I guess. Without the parenthesis you could believe that 10^7 has the unit W and 1.113 is unitless - most people won't care, I suppose.
Or
power of ten & unit --> paranthesis
one or both of them missing --> no parenthesis
Nice trick! 😉
Only works if the magnitude of the result of Q with varying parameters is the same.
Werner wrote:
Nice trick! 😉
Thanks, but not nice. 6 (Mega) is not nice number - the nice (fine) number is 7 - 7 days in week, 7 sounds in music, 7 colors in rainbow etc
See the picture
This is Excellent!!!
Thank you for the explanation.
