I'm using Mathcad 8.0. I have the following table of data from a colleague.
I want to build this table of data in Mathcad. Then I want to pick from it for downstream calculations. In other words, downstream, if D/2h is specified as 2.8, I want to pick K1 from the table as 1.27. How do I do that?
An added step would be to linear interpolate between data points on the table. In other words, if D/2h is specified as 2.5, I want to interpolate K1 from the table as 1.13.
There are many ways within Mathcad to solve this problem. Here's one ...
Stuart
Stuart
This is perfect. It does exactly what I was looking for. Thanks!
No problem. Glad to help. The Mathcad Community has several Experts who can give advice on a wide range of topics, so it's a good place to ask questions.
Stuart
