Can someone tell me how to create a piecewise function and the syntax that is involved. I have searched all of the help directory and can't figure out how they are creating the function (I cant replicate the syntax). I want to use an if statement.
Something like the image attached is what i am trying to replicate.
Matt
Does the attached file help, Matt?
Stuart
In the help contents go to the chapter on programming, and specifically conditional operators.
Stuart
Yes. Thank you that was exactly what i needed.
