Pipeline launch load
MikeArmstrong
I am struggling to write a program which will calculate the require pull force for given increments through out the pipeline installation.
Right, string 1 is 525m in length and will be pulled 55m from chainage zero before it enters the pre-drilled hole.
Once the string has passed chainage zero it will be submerged in Bentonite, denoted by w.sub_e_bent, before the pipe is pulled past chainage zero I is situated on conveyors, therefore the in air pipeweight is multiplied by a friction factor and the length left on conveyors.
If anyone can understand my problem and help iy would be much appreciated.
Regards
Mike
>If anyone can understand my problem and help I would be much appreciated. Regards [Mike]
_________________________
You complicate matters !
Try to debug by all possible attempts .
That should do.
jmG
Cheers for the help that works perfectly.
When looking at problems like that is it mandatory to have the arrays the same size?
Regards
Mike
>perfectly.
>Regards
>Mike
____________________________
You bet, when adding 10 oranges and 5 onions it's not going to make an apple pie ... at least not of my taste, neither Mathcad.
jmG
Class.
Regards
Mike
