Not sure what exactly you mean by complex "coefficients".
As far as I am aware the only pde solver which Prime offers out of the box is "pdesolve".
The help states that the boundaries have to be real values.
Ah, I forgot about "numol".
It looks as if the implemented algorithm only works in the range of real numbers.
But I could be wrong about that. Perhaps you could post a file with your attempted solution (possibly a simplified example which also shows the problem) here and someone else might then have an idea for a solution ...
Thank you very much, I have implemented some finite difference algoritm, It shows acceptable result,
