A question was raised if the capacity of an existing pneumatic conveying system, conveying HDPE particles, can be increased from 20000lbm/hr to 30000lbm/hr ?.
This worksheet shows the calculations with unit conversions used in the system evaluation. Summary of calculations results are given with the references.
Probably you could find an expert in the page relating to the mechanical engineering ...
>Sir,
> The question raised was rather general and does not reflect an
>existing system in reality.
>I took this, as an idea to use Mathcad Prime 2.0, as an example, with
>units to show the readers. I attach the pdf format to allow others who does not have Mathcad software, to see it.
>My mechanical engineering background was supported through the works I
>have done in DCS's for various industrial and power plants, also for the new
>geothermal power plant which is going to be used for the first time in
>Iraq.
>Regards,
>a allawi
