Does anyone know if the default font and settings can be changed?
Also, is there a way to set a signature up?
Mike
Mike
Have you investigated template files? Insert and change what you want, then "save as" a template (.mct) file.
I'm talking about the forum posts, not Mathcad worksheets. ![]()
Mike
Mike,
Did you want a font outside of the 15 or so that's provided from the font drop-down?
-Dan
Mike,
-Dan
Dan,
I wanted to change the font of my posts and add a signature.
Mike
Within the Text Editor, choose a different font from the drop-down menu. If the 15 choices isn't to your liking, you can use HTML tags to define the font you want.
No automatic way to post and attach a signature. You'll have to copy and paste text from a handy text file saved to your desktop or create an image of your signature and insert it as a picture.
-Dan
But each time I post I have to manually change the font. Is there no way to change the setting permanently
Shame, but not that much hassle ![]()
Mike
