I am using a program of 120 lines length, that can be handled in Mathcad 14 without problems.
Prime 3.1 however indicates "This expression can not be calculated because ist is to large".
Is there a general limitation in Prime 3.1 or is the problem created due to the transfer form MC14 ?
Günther Polz
No experience with limitations on program size as far as I know.
Prime complains about the expression, not the program. Can you take the expression separately and evaluate it?
Can you show the program?
Can you attach this Mathcad worksheet?
Thank you, Luc.
I would suggest you post the working MC14 file here,
You can do so by replying, choosing "Use advance editor" at the upper right and then "Attach" at the lower right.
Are you contacted with PTC's technical support (and send them your Mathcad Prime file)? Link for "Mathcad Support Center": Mathcad Support Center
