Prime character creation
wbell
8-Gravel
In Mathcad 15 you can create a prime symbol (') when defining a variable using the CTRL-F7 keystroke.  I am not able to do this in PTC Prime 6.  Please advise as to how this is done with Prime 6.
(To:wbell)
many keyboard shortcuts have changed from Mathcad to Prime.
Go to trhe calculate ribbon and when you click "Operators" you should see something looking like    x'   .
Mousover it and the tooltip help should tell  you the keyboard short which is appropriate for your language.
If you, like me, use a localized version of Prime, those tooltip shortcuts unfortunately often are wrong. In that case you have to find it out by trial and error 😞
(To:wbell)
