Prime is not playing nice with vector images
spaco
3-Newcomer
I installed Prime trial and I tried to insert a WMF image in a new worksheet.
Prime convert it to a raster image.
Why?
8 REPLIES 8
What is the issue with Prime converting it? Is it loosing quality?
Mike
http://communities.ptc.com/servlet/JiveServlet/showImage/2-149416-2532/bar_anim.gif
If I insert a vector image (WMF file) in Mathcad v14/15 and resize it, the lines remains always sharp, like in any cad program (because the file is vector type).
If I insert the same WMF file on Prime, it converts automaticaly the WMF file in a blurry raster image, the file size increase and the quality is very low.
So please add another missing feature for Prime.
mzeftel
(To:spaco)
Can you attach the vector image that is having issues, so we can investigate this. Or log it with technical support directly.
Mona
Mona,
I have just noticed that I can't copy/paste images from Prime. Has this feature not been implemented?
Mike
I attached an archive containing:
- one wmf file;
- xmcd v14 file with the image inside
- mcdx Prime file with the image inside.
The quality of the vector image is very good with v14 and very low with Prime.
Right I see what you mean now.
The image below has been taken from Prime.
I copied your *.wmf image into IrfanView (free software) and then copy/pasted straight into Prime. The quality isn't as good as M14/M15, but it does seem better than the Prime worksheet you posted.
I agree this is poor, but the above is a workaround.
Mike
The workaround does not change the fact that Prime is converting the vector image to a raster image.
V14 keeps the image as vector type even after resizing.
If you read my reply I did indicate that this isn't right - that's why I called it a workaround.
Mike
