Problem in solving a Biarc Interpolation Algorithm
ptc-6081990
Hello All,
I am facing an issue in solving the Biarc Interpolation Algorithm in mathcad. Please find the attached mathcad sheet and help me solving the issue. I am not able to figure out that why it is not giving the expected result.
Thanks a lot in advance.
(To:ptc-6081990)
You will have to explain why you think your sheet fails and what result you expected.
Your routine at least gives a result (assignments followed by inline evaluation sometimes fails in MC):
Hello Werner,
Yes, the answer given by you is the answer which I am expecting but in my Mathcad it is not evaluating the answer and all the code is in color red. It is also giving error as "mpl_exception".
Can you please tell how did you get the answer?
Many thanks for the help.
(To:ptc-6081990)
Well, the current MC15 does not throw that error but it simply is showing nothing after the evaluation equal sign.
The mpl_exception was quite common when doing calculations with matrices if you combined assignment and inline evalution.
The solution is simple: delete the equal sign after the routine which calculates your matrices and do the evaluation afterwards.
I guesss (and hope) that the attached file wil work for your version, too.
Thanks very much, it works very well now.
