This is MathCAD V2001i document wherein I show my initial
problem and two solutions that became apparent from the help
provided by the PTC Community. The solution provided by Fred
K. was closest to what I ended up using and was the simplest
for my one-dimension, stacked matrix. Paul
Paul,
Does really require a new document creating? You could have posted this within your thread.
Mike
Thanks for the tip. Will do. Paul
Use the option "Use advanced editor" to attach to the message your file.
I kind of like the document post.
The worksheet goes through a "cleansing" process within the discussion thread. And then the worksheet is remade into a document, all polished and shiny.
Then members can rate and comment on the document indicating how useful and elegent the solution is.
