Program not working
Abhishek71992
6-Contributor
Program not working
PFA the MATHCAD file. My program on page 13 is not working. Can you please help me.
TIA
Okay, you fixed the previous error.
I can't run your file (I've only got Express--no programming), so this is only a guess, but I'd suspect that the root function is failing to find a root.
Might want to see if you can localize that issue, and/or wait for someone with full Prime to take a look.
An impressive work!
Just a tip:  You can change the font size of just one math entry (like your program) to make it fit to the page just a bit better.  Select that entry, then math formatting and font size.  Adjusting this without selecting an area may change ALL of the math areas.
I think Fred is right.
Your function has "incompatible units" but gets down to the call to the root function.
Put a "return" just prior to the root call to examine the root parameters.
Good luck.
Trying to add a length and a dimensionless quantity can't work.
Check your equations and units.
Thanks Werner
