Hi, I need assistance debugging a program to build a Z-score table with the intention to reproduce in Mathcad a z-score table very similar to the one that we could create with an excel spreadsheet. This just for fun!
See attached files.
Thank you
juan
> I used the integral instead of the function pnorm because this is the only way that I can funnel the sum of the vectors X & Y into the limit of integration Z.
I see no problem in using that sum as argument of the pnorm function.
> Your suggestions of modifying T did not work for me
Additionally you have to use Z instead of T in the last line. After all you want a Z-table, not a T-table 😉
Werner
Why do you post a pdf and not the worksheet itself??
Guess you should use T[r,c as upper limit of your integral in makeTable and not simply T.
Better way is to write T <-- a[r + b[c and then use T as upper limit as you have. No need to create a vector T.
Why do you program the integral yourself? Mathcad provides the "pnorm" function!
Hi Wegner,
Finally I could upload the Mathcad file now. I tried many times at the time of sending my post without success. Here is the file to be look at.
If you can do it using both methods is excellent, then I could compare both of them
thank you!
juan
Werner
Hi Wegner!
Wow!!!!!
You are simply the BEST, like Tina Turner's song .
I posted a previous problem some weeks ago concerning debugging a long expression for calculating the alcohol density given some temperature and some alcoholic strength. Luckily, one of the user identified my error and I got the expected results. Back then, my idea was to build a table similar to the one that you have just elegantly programmed. I was working on that too, modifying your procedure to suit such a long expression. I tried many different ways without luck. Here I attach the Mathcad worksheet and the density table as guide for a fix. I worked with a small subset of a whole table, with temperature ranging from 10 to 20 and the alcohol strength from 0.50 to 0.59. Have a look please, and tell me if there is a solution. Thank you!
juan
juan suarez wrote:
Hi Wegner!
The "g" should still be an "r" 😉
Two errors:
1) t is a range but it has to be a vector to be able to be processed by the program
2) Your table make program uses t an p but should use the appropriate elements of the input arguments a and b instead!
Werner, I am so sorry for massacring your name. It was unintentionally. Why did you let my errors run for such a long time without warning me? You made me realize that I was mistyping your name since the beginning of this thread. I apology for that. On the opposite side, I celebrate your expertise and know how. You are really a very smart guy, a genius! People @ PTC need to hire persons like you!!
Your fix and your trick, worked awesome. After your brilliant fix, I modified your code to turn the first row into a column vector and the first column into a row vector to simulate the arrangement like in the alcohol density table attached earlier.
Thank, thank you very much.
regards,
juan.
No real problem 😉
Glad you got what you were looking for.
Please attach your Mathcad worksheet.
I attached in a previous post last night , but it is waiting for the moderator for approval (more than 16 hrs). I resubmit it again.
did you get the spreadsheet? I's is already published. Any suggestion concerning the last post?
