Programming - if statement
rayakannu2
6-Contributor
Can anyone help me correct this simple program using the "if statement"?
LucMeekes
(To:rayakannu2)
8 REPLIES 8
rayakannu2
6-Contributor
(To:rayakannu2)
I was able to correct the problem!
Can anyone help with the plots?
LucMeekes
(To:rayakannu2)
Is continued here:If Statement & Plots
rayakannu2
6-Contributor
(To:rayakannu2)
here is the xps file
(To:rayakannu2)
replace the last line "[x,y]"  by  "augment(x,y)".
You don't have to write a program:
This is excellent!!
rayakannu2
6-Contributor
(To:rayakannu2)
Fred, how do we get values of slope and y for a particular value of x?
If you look closely, you can find these expressions in your program
If you meant that   y' = 2(1+x) - y,
