Programming success
MikeArmstrong
Programming success
Hi Guys
Thanks for all your help with the programs and calc�s etc.
I have attached a copy of a pull force calculation which I completed sometime last year, as you can see the way it was wrote was messy and required hiding.
I have attempted to write my own program presenting the results on the graph.
HOPEFULLY SUCCESFULLY......
Any improvements or suggestions on the program will be of great help.
I know the input matrix should be changed to an excel table, but my main worry is getting the programming right.
Cheers in advance.
Regards
Mike
Simpler version of your Pull functions can be created by calculating the cumulative values of string in advance.
stv
MikeArmstrong
(To:alnstevens)
Cheers for that look alot better.
Regards
Mike
