Greetings to all.
I have a table (Table 1) with a large number of components (A1, A2, etc.) which in turn contains another large number of elements (E1, E2, E3, etc.), whose values necessary to perform operations are in another table (Table 2).
Based on the table1, I need to get the values of the elements forming part of each component (eg A1 (E1, E3), A2 (E2), etc) to perform subsequent operations.
To better understand what I want, I attached an example of what I have to do, and I want to automate as I do it manually would take me a long time because as I said earlier Table 1 has a large number of components ![]()
in advance thanks for the help
Bryan Pérez Pérez wrote:
Greetings to all.
Do you mean something like the attached? I haven't tested it properly, but it might act as a starting point.
Stuart
Hi Bryan, yes I believe it will be possible, but I am not entirely sure what you how you want it automated.
Where is the selection of the component?
Greetings to all.
Stuart
Nicely done Stuart.
It's perfect, I made small modifications to work with the data table that I require and works great.
Thank you very much Stuart
Bryan
You could simply this problem considerby by removing the strings.
No worries, Bryan.
Stuart
