Question regarding READPRN
eakgn
I am able to successfully import data via a text file (.txt) by using this READPRN command. However when the .txt file changes (i.e. data change), the import matrix in MathCAD is not automatically updated. I need to close the program down and re-open to have the updated numbers.
The question here is, whether if there is a nicer way to do this? Another command maybe?
I know I can always do right click “disable evaluation” and “enable evaluation”, but the problem is I open/use this Mathcad sheet through an easy batch code for an another program, so mouse commands are not an option for me.
Thanks in advance!
RichardJ
(To:eakgn)
Select the READPRN statement and hit F9.
eakgn
(To:RichardJ)
Thank you for the reply. I didn't know about F9 and in future it will help me for sure.
But it is unfortunetly not helpful for the above stated problem. I am trying to automize a process and I want MathCAD to do this refresh job (F9) either automatically or by an another command.
So far I am able to accomplish this by using following batch codes:
start "C:...\main.xmcd"
taskkill mathcad.exe
But closing & opening mathcad every time in order to refresh some data is brutal and I am looking for a nicer solution.
RichardJ
(To:eakgn)
Mathcad is not the right piece of software to automate a process. There's no way to make it continuously poll an input and update when the input changes. It's simply not designed to do that.
Which version of Mathcad are you using?
