Please see the attached for the question.
Basically I would like to know the analytical solution to my differential equation.
And why would the solve block give different solution after a parameter, t, is changed (Given the same initial guess)
The strange things is it seems to be the solution of the two constant I am solving should not be dependent on t, so they should not change when I change t.
This is a case specific problem.
BTW, can someone tell me what is the general solution to the system of differential equation
x' = x+y
y' = x-y
is it exponential function or trig ? I have difficulties looking it up because I don't know what class of problem is this...please provide a keyword for me to research on it.
Henry
You have three variables (A, B and t) and only two equations, so you may chose one of the three freely:
Lets assume a=1 and choose any A (A>1!!)
Then B=(2-A)/(A-1) and t=ln(A-1)*(A-1)/(2-A^2)
or B+1 = 1/(A-1) and t = ln(B+1)/(A-B) = ln(A-1)/(B-A)
So there is only a very limited range of t you can expect a solution.
Most solutions find finds are due to the tolerance set and are not solutions - e^At and e^Bt appear to be zero (which they aren't).
x' = x+y
y' = x-y
Differentiate the first equation wrt t again: x`` = x` + y`. Substutute for y' from the second equation: x``=x`+x-y. Replace the y that remains from the first equation: x``=x`+x-(x`-x). This gives: x``=2x. You might find this easier to solve.
Alan
