Quick question; Proper way to define multiple vector values
dsochor
What is the error with the syntax in the attached program? I am attempting to define multiple values of a vector depending on the previously assigned variables. I am expecting the vector to have two rows but only one results.
StuartBruff
(To:dsochor)
Although the above is in Mathcad 15, the same applies to Prime.
Stuart
9 REPLIES 9
LucMeekes
(To:dsochor)
Post your sheet. From the picture it's difficult to see what is an index and what is a literal.
StuartBruff
(To:dsochor)
Stuart
LucMeekes
(To:dsochor)
Found the culprit. The function delivers the last statement as result.
Add a last statement that returns the desired result,
such as:
Note that Mathcad usually starts vectors and matrices at index 0
dsochor
(To:Fred_Kohlhepp)
Another quick question (want to avoid creating another topic). Why does Mathcad not see NaN results? In the attached jpeg, c_ac is NaN but the if statement won't recognize it.
LucMeekes
(To:dsochor)
I guess it's one of those.....Prime things. This is what Mathcad say about it:
Must be your older version of Mathcad.  Here's Mathcad 15:
MJG
18-Opal
18-Opal
(To:dsochor)
You have to use the IsNaN function:
dsochor
(To:MJG)
Perfect, thank you!
