READEXCEL problem in MC15
  • November 4, 2010
  • 3844 views
Hi folks,
I have an Excel file consisting of 26 work sheets full of data. With the READEXCEL command I'd like to read them in, however:
  1. READEXCEL doesn't read all the work sheets, but from 0 through 8
  2. However, backwards I'm able to read from 26 through 10
I have checked whether there are some format problems on the sheet 9 or 10 but to no avail. This really puzzles me. Is there some kind of bug or does anybody see a flaw in the attached MC15 file?
Sorry, but it has to be in MC15 otherwise the READEXCEL command doesn't execute.
Thanks in advance
Raiko
Best answer by MikeArmstrong
It's because you have called your sheet ch 9 - CH 9.
Change it and it works.
Mike
Mike
Raiko17-PeridotAuthor
Thank you Mike. Must have been a case of code blindness-the weekend is nearing
Raiko
Not a problem.
Took me a while to spot it. As you said, its nearly the weekend
Mike
