Range of answers from multiple equations
ptc-4156096
I'm new to Mathcad / Mathcad Prime so please excuse this if this is a very easy solution.
I'm attempting to work a physics problem which has a range of answers based of a range of values for VsubF. When I work th solution for a single value I get the answers I expect. However when I work the range function my Delta equation (marked with stars on file attached) only gives me a single value instead of a range as expected.
Is there a better way to work this so I get a range of values for my Delta equation and then also my Av equation? I attemped steppiing VsubF using 20,30,...200, but running into some issues there as well.
Thanks for any assistance.
Tyler
It will be good to use the vectorizition operator in all user's operators - see the picture and the attach:
See too http://communities.ptc.com/docs/DOC-2352
6 REPLIES 6
I fully agree Valery. The only issue I have with using the vectorize function is for ascetic reasons. It does tend to make the calculation complex.
Mike
Valery,
I think you have made a typo on the definition of R. See attached.
Also, we don't have to vectorize everything in the calculation.
Mike
Mike Armstrong wrote:
...Also, we don't have to vectorize everything in the calculation.
Mike
I agree.
Mike, you attach a file for Prime 2.0 version .
Oops, I'm having a few issues with Mathcad Prime 1.0 license.
Mike
Thanks Valery and Mike, I have lots to learn. Thanks for sending me along the right path.
