Range variables problem
yeet
Hi everyone,
I am trying to do some calculations using Mathcad 14 but I have a problem where variable of a function can't be assigned to a range of variables.
I am attaching the sheet, it would be appreciated if one could point the error.
StuartBruff
23-Emerald V
(To:yeet)
Yigit Turgut wrote:
Hi everyone,
Yigit,
The reason for the problem is that when you make assignments using range variables as indices, then all range variables must appear on the left hand side of the assignment. The error message in this case arises because you don't use f on the left hand side.
I'm going to assume that you really want to sum over f in the right-hand expression, in which case the most obvious method is to use the range variable summation operator (available through the calculus toolbar). See attached.
Stuart
StuartBruff
23-Emerald V
(To:yeet)
Yigit Turgut wrote:
Hi everyone,
Yigit,
Stuart
Or he could just use your vec function to create a vector instead of using a range variable.
Mike
Thanks for the reply that seems to work for that far but I have a following problem where an index of an array can not be assigned as a matrix, for detail please see the attached file.
yeet
(To:yeet)
Sorry for the description, the problem is that the expression tries to take square root of the matrix which cholesky decomposition seem to be helpful.
