I have a range of numbers that I am Using. Is there anyway to make the range show up as a slide rule bar? For example a user goes on and then clicks on a slider that allows him or her to set the bar to a specific number in that range?
D
"Insert", "Control", "Slider", then right click on the slider to change it's properties.
exectly like the attatched.
D
Would you mind telling me how you did it? I would really appreciate it.
D
Thank you Richard.
D
Can't believe you got the gold star in this thread ![]()
Mike
Sorry Mike. You were very helpful.
D
I was only joking ![]()
Mike
Ha Ha Ha! I got more points than you!
Of cousre, since we both have diamond status we can't go any higher, so that doesn't make a bean's worth of difference ![]()
Drinks all round.....
Mike
