Re: Matrices Create in Mathcad Prime
@SPRstructur wrote:
The reason why I repost because I can not edit to rotate pictures.
You CAN edit your own post (the 3 dots at the upper right) and so you can delete a pic and replace it by a correctly rotated one.
Furthermore you could have simply put a new answer in the first thread instead of opening a new thread.
Yes, the delta is segment-Length-provided-user to find number of segments of elements L. You can ignore it.
So why did you post it?
Turn to original.
Which is still not clear as to what exactyl you need. Do you mean that n is the very same value for all elements of L? Then this should be what you are looking for:
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
